errea file openings chess
  • Thread starter Thread starter danitomarzovito
danitomarzovito
good morning, I have a problem..I have to open a file shape inside a dwg; amount the shapes files (me from the error, but it ends the loading) then when I go to open them it comes out written: error: the source of data tables is not connected (no active session) or internal ase error: no current connection.
What can I do? thanks to everyone for the answers
among the things you can do is explain yourself better:-)
the file shape as you call it is a file that comes from a gis or an autocad form file?
Does your flle have shp or shx extension?
with which command do you charge it?
error messages that cites seem to be linked to links to databases present in the drawing.. .
do you have a car?
do you have a car?
I thank you for the answer, but I solved that problem! I open the map sheet table, I click on the particle number but the selection on the dwg design is so small and imperceptible that I cannot find it in the drawing; Is there a way to highlight it? Thank you.
If I understood your question well....
options > selection > settings and colours of the selection, e.g. the size of the grip.
