error [-25]
  • Thread starter Thread starter jasmtn
jasmtn
Good morning.
I'm putting myself to nx for a specific project.
I don't have a license on my location, but I have to bet on a server that's in my Frances.
insert the var splm_license_server to the ip address of the server 28000@xxx.yyy.zz.ww.
ping xxx.yyyy.zz.ww shows what communication there is.
when I launch nx, I get this error as from image attached.
Capture.webpnote that it is nx1872.
other users with same conditions (nx1872 and point on the same server) do not have this problem.
I always put 28000@nomeserver and not address ip. Are you sure other users use the same syntax?
does not change anything the nameserver - I always get the same error code [-25]users in question use the same nx1872 and bet on the same server either by namersevrer or ipserver.
Thank you for your help.
What version do you have of the licensing tool? I have 6.1.3.1 and it works with nx1876.
the latest version of nx (that of June 2019) uses a new version of flexlm
What version of nx are you installing?
