help.project
Good day to all,
I am to expose the following problem (that until now had never been presented)that I had with the use of revit 2010.
I press that:
-I made a planivolumetric model consisting of 3 sheds plus the road and the green around.(with rich vegetation)
-The file has the size of 19 mega.
During the rendering process, when I set a maximum resolution of 600 dpi, the image is not fully rendered, but, to make you the idea, as if the rendering calculation is still in place. . )
In particular I have an image with correctly rendered parts and other parts with large pixels as if the calculation should end.
This happens to me when I impose a 600dpi resolution, with a lower resolution, 300dpi, this problem has never arisen.
what can be the causes and possible solutions to this type of problems?
Thank you in advance,
Good day
I press that:
Good day
