error folder
TECNOMODEL
this morning at the launch of inventor appeared to me this messageCattura.webpIf I open the indicated folder I see that there are several files, but I'm afraid to mess up something.
suggestions?
hi, being temporary, there should be no problem (even because when you close, the commands are no longer available).
the problem I think is that your disk is reempting with all the inconvenience of the case (virtual memory first, if allocated them).
in any case I hope that some experts will deepen the topic
In fact the record is full, I'm waiting for the technician for enlargement.
I solved by freeing some space.
the local/temp folder contains your temporary files. every now and then it gives a nice emptied, as well as that of windows. but that by emptying everything you lose also all the useful psw. I do this about once a week.
