jim78b
cerco di cambiare il tasto di ovveride dello snap endpoint shift+p e non me lo fa cambiare dicendo questo
see the end of this message for details on invoking
just-in-time (jit) debugging instead of this dialog box.
************** exception text **************
system.nullreferenceexception: object reference not set to an instance of an object.
at autodesk.autocad.customization.temporaryoverride.fillpropertybag(ipropertybag bag)
at autodesk.autocad.customization.propertycontrol.setproperties(customizationelement item, cuitreenode node)
at autodesk.autocad.customization.mainform.shortcutsgroupeventhandler(object sender, shortcutsgroupeventargs ea)
at autodesk.autocad.customization.shortcutsgroup.fireevent(shortcutsgroupaction action, uidpair uidpair)
at autodesk.autocad.customization.shortcutsgroup.listview1_selectedindexchanged(object sender, eventargs e)
at system.eventhandler.invoke(object sender, eventargs e)
at system.windows.forms.listview.onselectedindexchanged(eventargs e)
at system.windows.forms.listview.wmreflectnotify(message& m)
at system.windows.forms.listview.wndproc(message& m)
at autodesk.autocad.customization.listviewex.wndproc(message& msg)
at system.windows.forms.control.controlnativewindow.onmessage(message& m)
at system.windows.forms.control.controlnativewindow.wndproc(message& m)
at system.windows.forms.nativewindow.callback(intptr hwnd, int32 msg, intptr wparam, intptr lparam)
************** loaded assemblies **************
mscorlib
assembly version: 2.0.0.0
win32 version: 2.0.50727.42 (rtm.050727-4200)
codebase: file:///c:/windows/microsoft.net/framework/v2.0.50727/mscorlib.dll
acdbmgd
assembly version: 17.1.0.0
win32 version: 17.1.51.0
codebase: file:///c:/programmi/autodesk/acadm%202008/acdbmgd.dll
msvcm80
assembly version: 8.0.50727.6195
win32 version: 8.00.50727.6195
codebase: file:///c:/windows/winsxs/x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.6195_x-ww_44262b86/msvcm80.dll
acmgd
codebase: file:///c:/programmi/autodesk/acadm%202008/acmgd.dll
acinfocenterconn
codebase: file:///c:/programmi/autodesk/acadm%202008/acinfocenterconn.dll
adinfocenter
codebase: file:///c:/programmi/autodesk/acadm%202008/adinfocenter.dll
codebase: file:///c:/windows/assembly/gac_msil/system.windows.forms/2.0.0.0__b77a5c561934e089/system.windows.forms.dll
system
codebase: file:///c:/windows/assembly/gac_msil/system/2.0.0.0__b77a5c561934e089/system.dll
system.drawing
codebase: file:///c:/windows/assembly/gac_msil/system.drawing/2.0.0.0__b03f5f7f11d50a3a/system.drawing.dll
autodesk.interop.acinetengine
assembly version: 17.1.51.0
codebase: file:///c:/programmi/autodesk/acadm%202008/autodesk.interop.acinetengine.dll
adinfocenter.resources
codebase: file:///c:/programmi/autodesk/acadm%202008/en-us/adinfocenter.resources.dll
accessibility
codebase: file:///c:/windows/assembly/gac_msil/accessibility/2.0.0.0__b03f5f7f11d50a3a/accessibility.dll
system.xml
codebase: file:///c:/windows/assembly/gac_msil/system.xml/2.0.0.0__b77a5c561934e089/system.xml.dll
system.configuration
codebase: file:///c:/windows/assembly/gac_msil/system.configuration/2.0.0.0__b03f5f7f11d50a3a/system.configuration.dll
h5zfnuag
aclayer
codebase: file:///c:/programmi/autodesk/acadm%202008/aclayer.dll
acmgdshared
codebase: file:///c:/programmi/autodesk/acadm%202008/acmgdshared.dll
acmgdinternal
codebase: file:///c:/programmi/autodesk/acadm%202008/acmgdinternal.dll
aclayer.resources
codebase: file:///c:/programmi/autodesk/acadm%202008/en-us/aclayer.resources.dll
accustomize
codebase: file:///c:/programmi/autodesk/acadm%202008/accustomize.dll
accui
codebase: file:///c:/programmi/autodesk/acadm%202008/accui.dll
accustomize.resources
codebase: file:///c:/programmi/autodesk/acadm%202008/en-us/accustomize.resources.dll
system.data
codebase: file:///c:/windows/assembly/gac_32/system.data/2.0.0.0__b77a5c561934e089/system.data.dll
system.design
codebase: file:///c:/windows/assembly/gac_msil/system.design/2.0.0.0__b03f5f7f11d50a3a/system.design.dll
autodesk.autocad.interop
codebase: file:///c:/windows/assembly/gac_msil/autodesk.autocad.interop/17.1.51.0__eed84259d7cbf30b/autodesk.autocad.interop.dll
************** jit debugging **************
to enable just-in-time (jit) debugging, the .config file for this
application or computer (machine.config) must have the
jitdebugging value set in the system.windows.forms section.
the application must also be compiled with debugging
enabled.
for example:
<configuration>
<system.windows.forms jitdebugging="true"></system.windows.forms>
</configuration>
when jit debugging is enabled, any unhandled exception
will be sent to the jit debugger registered on the computer
rather than be handled by this dialog box.
ho autocad 2008
mscorlib
acdbmgd
msvcm80
acmgd
acinfocenterconn
adinfocenter
system
system.drawing
accessibility
system.xml
h5zfnuag
aclayer
acmgdshared
acmgdinternal
aclayer.resources
accustomize
accui
system.data
system.design
enabled.
for example:
<configuration>
</configuration>
ho autocad 2008
