error in displaying retini
  • Thread starter Thread starter Ucp1985
Ucp1985
I am claudio, I have autocad 2013 and use windows 7 professional, my problem is as follows:
In practice as I mentioned in the title I have problems in the display of the retini, I explain better.
I have a table made by my colleague on another pc and if I open it, some retini (not all) appear full, as they were solid but not so. Can you tell me why?
the strange thing is that this change happens when the drawing opens.
or does it happen to you if you change prop to a retino? (for example, do a matchprop, or change the hold scale)
in this case test the variable value measurement and compare the value of your pc and the value of your colleague.
solved!!! :
in a few words, on my autocad was set badly a value of a variable as it establishes the retino area.
the variable in question is hpmaxlines I had a value like 16000 instead it was brought to 1000000.
Thanks anyway it is hoped to have been of help for someone else.
claudio
Sorry but I have the same problem yet as a variable I set 100000000, possible that the problem is in another factor?
