GioC94
Good morning
I have this problem: after opening a step file, I would like to save it as a whole. in the old version of solid that I had time ago, this passage was automatic and it worked well, i.e. at the time when it saved the assem as an asm, it created the subfolders and saved all the subaxis and the attached parts.
now that I went to sw2020 when I save the file, after opening the step, saves in the destination only the asm file, but does not save any of the parts/subassiem to him bound. As a result I find myself:
1) the file that, even after saving it asm, remains in the title in the top screen of solid with the asterisk as if it were still to be saved
2) more importantly, opening the saved asm file, I do not see anything because it does not even find one of the parts/subassiemi tied to him. remains as if there was nothing.
As a result, I should make explosions of these assemblies, which in the previous version I did without problems, but now I can't even open the parts from the tree to the left.
Is there any box to check in options, maybe performance or import, which I have to activate/reactivate?
