error installation 1603
  • Thread starter Thread starter stefra
stefra
I have the following problem:
launch the installation of inventor suite 2010 and at the end of this does not install autocadmechanical and the content library indicating me error 1603....
I press that I use xp sp.2 and the machine has been formatted, my only doubt is that the video card does not fall into those certified by autodesk .
Can the problem be attributable to the video card or is there anything else to try? ?
I don't think that the video card can affect the installation of a program, it can create case problems ever while using it.. .
have you updated windows (by the way, what do you have?) and flash?
my s.o. is xp sp.3; cmq I uninstalled everything, updated from sp.2 to 3 and the error is not reappeared .
all right x luck. . thanks to the interest
hi I have your own problem, you kindly protest me to explain the procedure you followed.
once appeared error message 1603 , I uninstalled the inventor and updated my operating system (win xp home) from sp.2 to sp.3 .
at that point I reinstalled inventor and everything went well.
That's it.
