error to access revit
  • Thread starter Thread starter geom.Silvio Pellegrini
 error only
every time I enter in revit before opening revit asks me to press on the ok of this message: "unable to execute the archvision content manager executiable was not specified" how can I fix it?
If you installed the rpc there's something that didn't go well.
But if you're okay, the software keeps working or arresting?
I would try to uninstall rpc and, at the limit, reinstall it.
I autodesk revit architecture 2010 I have mounted it on the pc for almost a year and it is only in the last week that this error comes out to me.
if I give him the ok part revit without any problem is only a little slower to load. You know what that could be? or what can I do to solve it? because I tried to insert the revit cd but it doesn't let me restore the system so I should uninstall and reinstall everything by losing the icons and all the settings I have.
It can happen that over time in the system register you create a bit of confusion. a my advice is to download from internet programs like ccleaner or similar and occasionally give a nice cleanup to the register and a "defragmented" to the hd... and then proceed as he recommends: uninstall and reinstall the rpc.
If there are no other big problems it should work.
Greetings.
