error with local sampling
  • Thread starter Thread starter blue.cat
blue.cat
Hello everyone, I am entering the premises in a project executed with revit 2010, only that the colored sampling of the premises overlaps the walls making them invisible (first image). how to see the furnishings remain visible while the color "becomes" on the display of the walls.
I tried to change in the properties of the view the color scheme position, which is already on "background"; putting it in "first floor" the furniture disappears.. .
if I avoid the elements of delimiting the local seems to be all right (according to image). . .
Can you tell me how to correct this problem? Do I have to change some settings?
among other things this is the plant of the ground floor, if I pass to that of the first ppiano the error is not there.
when you do not forget the wireframe activated :biggrin: it is usually a problem related to the calculations of the video card....I solve simply by zommando a little and then regretting or regenerating the view by closing it and reopening it.
