error with pdf inserted as an ole object in the dwg
jim78b
I put a pdf of a 3d that I did in a dwg design .I created the pdf with dwg to pdf x have a good resolution I printed it on a0.ok insert as ole ..riduco ..salvo reopen the dwg and tells me that it has to do a recover !he does not like pdf!
I tried to do pdf with adobe pdf ... puts a lot of time to do it on a0 but not from problems ..how ever?
I could not attach 1 image ?only chr I would like to make sure that the image fixed always included and not attached .
old questions, we've already talked about it a long time ago.
he does not want to remember to transmit attachments to the dwg, nor to use e-transmit, for its deformation
everything has to be in one dwg file, without worrying about problems and/or heaviness file.
what sense does make a pdf a0 of good resolution and then insert it as ole boh.
save him in jpg then, nothing changes.
and above all keep your problems, since solutions exist but are not applicable to your emotional limits.
right these days I have received files from an architecture studio, via wetransfer. 270mb, wow what will they have ever done?
20 files, all oscillating from 200 and 300kb, each pointing to a series of 10 mega xrifs (always the same, but duplicated in 20 folders).
result: 270mb transfer for files that could weigh 10 to the maximum. I looked at them and thought: I'm not telling you what I thought:)
