andrea.boerio
Good day to all,
I have just arrived, cause change of work, on sw10 from inventor (I had used already sw until 2005) as soon as possible (right), I will make a presentation, at this moment I am in the office I needed to try to see if some pious soul can help me with a practical problem.
I am trying to use solidworks explorer to search for parts/axis/signs by exploiting the possibility of searching "for property"
in our side files I have introduced properties (file\propriety\custom list...) with our names, which are recalled in drawings, boms and so on. everything seems to work here.
e.g.
ownership > > value
mass
mass
mass
I want to find those documents where the mass parameter1 is set to 120
in the search field of swexplorer
- if you type "120", or 120, you find me all the documents that report "120" somewhere;
- if I type, as I thought I had to mass1: "120", or mass1: 120, I find nothing;
- if I type "mass1" I find the documents where the string is present or where that property exists;
search paths are set, I tried to look around for guides if I am formatting badly the search string, but I do not go out.
Sorry, I think it's a banality, but I'm stuck.
thanks in advance,
a.
e.g.
ownership > > value
mass
mass
mass
thanks in advance,
a.
