errore irreversibile unhandled e06d7363h exception at fd6ccacdh
reggio
Hello, since week I have problems on the pc at home, suddenly appears to me "unreversible error unhandled e06d7363h exception at fd6ccacdh" and then closes me acad2010.. .
I tried to google but I didn't find anything useful, could you help me?
Does he do it with some files in particular? or after some command?
... uhmm now that you make me think, after I leave it on for a while (it never does it immediately launched) to open another design... So to see her like this, I'd say she's tied to the open command... only he doesn't always do it.... :confused:
You know what that means?
...uhmmm the sp is mounted, but apparently not needed.. .
Do I have to format?? :frown:
try installing the 2012 trial and see if you have the same problem. but the crash happens to you to do what in particular?
hi, as I wrote above, it seems to be tied to the command open even if it does not always, and never to the opening of autocad or the first files, so I know that,
before "impaciugare" the pc with various trials, I will try the way of "set the value of the "number of recently-used files" to 0."
e06d7363h is a type of code that can result from various issues.
while in fact fd6ccacdh is not in any research.
...in fact, the weird thing is that I have a final code that google doesn't find in the world...
In any case, as I said, the similarities of problem are there and therefore I will try first putting zero, and then after qlc day of trial I will tell you if I solved :d
Oh, my God. It gives me the same mistake...
rather than format... I keep the mistake...
thanks to all
