errors on frame created with frame generator
  • Thread starter Thread starter Maurog
Maurog
hi to all I have created a frame with frame generator, angles that are carved, that join 45°.... and so on. a son of modifications now next to each profile there is the " i " which if I put on with the cursor tells me: the frame member contains a reference to nonexistent geometries. I can't remove these mistakes and I should do it as going forward to insert parts whenever they place a constraint turns out to me error. I can't fix the profiles to remove the error. If I open each profile it would seem to be fine. Thanks to tt.
But isn't that you canceled and remade lines in the skeleton sketch?
In this case he gets mad at this message.
