joe
Is there a system to export all the coordinates of points drawn in a dwg from autocad to excel?
thanks to the attention
Thanks was what I was looking for!test the command Eattextis identical to extinct
see here:I can't use the command for what I need... .
I basically have points of which I would like to export x,y and z coordinates...
These points are not a block, but even if I create it returns all values equal to 0.....
If you can put numbers on autocad points then yes, but since it is not so....use blocks with attribute, so you have the opportunity to put in all the data you want!I'll explain better.... wouldn't it be possible to export the numbers I put on autocad? ? ?
Of course you don't work on your autocad for mac. are not supported on mac os x platforms.Hello, everyone. I have a problem. I use autocad 2015 for mac, and I have to import coordinates from autocad to excel. the problem is that I do not know why but do not work the lisp, and besides does not work the various preset commands for the acquisition of the coordinates. ...
