esportazione pdf
  • Thread starter Thread starter bboxster73
bboxster73
to all
I have a problem with pdf export since I went from wildfire 3.0 to wildfire 4.0.
if I carry a table in pdf in another famine that is not the workbook, for example with the test name_1.pdf, the latter is created to me.
I go to my table, edit (views, odds,...) and save again as pdf in the same folder before, then I remain surprised because in the dialog box "Save copy" you do not see the test_1.pdf previously saved. and if I try to export with the same name, pro/engineer sends me a warning saying that a file with this name already exists and then will be replaced.
the other side of the problem is that try_1.pdf not viewable with the browser of pro/engineer (by browsing all the folders, I see asm, prt, dxf, drw,....) but not my pdf file.
and by browsing with windows instead, I can see it in the folder.
I tried almost all builds of wildfire 4.0 (m010, m020, m030, m050, m070, m080, m090) but nothing.
What can one tell me?
