estensioni file
  • Thread starter Thread starter pierocampana
pierocampana
hi, being a new user, surely wrong place or discussion, take patience, but I would like to ask you to solid edge, as you can't do to remove from the display of the opening of files, (.asm,.part, etc.etc.), the extensions type _mir(.mir) that having the same name of the original files, you go to add to the first and so 'you will see an infinity' of "copies", where I find the Thank you. See you soon. :biggrin:
when you are in assembly and make the mirror copy in the window that comes out there is the possibility to rename the file, but being a specular copy is not identical to the file that generated it, otherwise it would not make you a copy but placed the original piece rotated.
However if you open a specular file ..._mir.par and right click on the "part copy" feature and click on open opens the original file from which it was created
I thank you for the same x explanation, but I wanted it not to be displayed in the dialog or file opening, so x be faster in identifying only the components that interest me.
I renew my thanks x your kindness.a presto.:redface:
in the v20 I do not remember if there is the possibility, try to select all files with _mir and with the dx button see if there is grouping, so you put them in a container.
