Sandra_ME30
the_luke 11:19
Good morning to all, I am using autocad 2016 to create a toothed wheel. first of all I drew a single tooth (formed by spline, circles and connection rays) which I then multiplied using the polar series command.At this point I added the circumference of foot to merge each tooth to the next, my problems start here:
-I would like to combine the teeth to each small arc of the base circumference but using the "unisci" command I do not reexit. select the element obtained from the polar series (the profile of the teeth), select the various arches of the circumference but using the "unisci" command I get "0 united elements" and I really want to understand the reason.
- starting from the profile of the wheel I would like to proceed with the command "extrude" so as to make my design three-dimensional. I select all the elements of the profile but the various teeth, obtained from the polar series, are not extruded. On the contrary I get the extrusion only of the small arches of the circumference of foot.
I attach some images to better understand my situation. Finally I noticed that even doing other forms, easier, with the polar series command the extrusion is however impossible.
Do you have any idea how I can solve my problems? Thank you.
Annex 42691 Annex 42690
I hope the_luke reads and registers again on the forum.
Sandra
Sandra
