etichette locale
  • Thread starter Thread starter CAROLINA
CAROLINA
after identifying a local I can't understand why when I go to assign the local label comes out this message: "no one of the created elements is visible in the floor plan view: 1 - first floor sp. may be appropriate to check the view or region of active plant, its parameters and its visibility settings." But on display hidden elements there is no hidden label.... .
Can anyone help me?
thank you dear
there may be several reasons... It is not easy to say which.
First thing would be: visibility graphics > room tags
I checked in vg, but "local labels" came out correctly, so it should be visible, but it happens that I can assign the area to the local, then when I go to assign the label or not hook it up then I go to "show hidden elements" and I see the label as if it had been hidden, but if the seleziono does not make me discover it in the view.
or I happen to be able to hook it up, but from " redundant premises" while being the area perfectly closed.
I can't begin to solve the problem.. .
You can help me
p.s: I could attach the file to you, but in what format?me it seems not possible to attach a file of revit.....or wrong
thank you dear
if you can see the label in the window showing hidden items, select the label and then select one of the options to reveal the item or category.
you do not need to start another message for the same question.
