Pano
I have the following mechanical system in which the 3 axes motor meet in one point (spherical pole)
I have to evaluate the drive torque necessary to the first motor (the green one) to rotate the whole structure.
I positioned the center point of the axieme on the center of the reference system that I added to the motor and aligned the axes so that the blue axis (axis z) of the sdr of the concida motor with the axieme y axis y.
at this point, having done some research on the web and read pdf various, I have to use the second eq cardinal of the dynamic so that:
what is not very clear to me is what value of j shown in the physical props of the axieme I must use
I have to use i2 (wikipedia should be[SUB]yy[/SUB] of the inertia tensor) in the main card? or any value in the global card?
I have to evaluate the drive torque necessary to the first motor (the green one) to rotate the whole structure.I positioned the center point of the axieme on the center of the reference system that I added to the motor and aligned the axes so that the blue axis (axis z) of the sdr of the concida motor with the axieme y axis y.
where[SUB]m[/SUB] is the couple motrice, c[SUB]r[/SUB] the strong couple and j the moment of inertia.c[SUB]m[/SUB]-c[SUB]r[/SUB]=j*(dw/dt)
I have to use i2 (wikipedia should be[SUB]yy[/SUB] of the inertia tensor) in the main card? or any value in the global card?Thank you.
