Per5
hi guys, someone managed to improve the slowness of the table with version 2015-2016. I started using it seriously but the design part is slow, sometimes exasperating.
this is not autocad, the lines are not two-dimensional as you think and each entity is parametric and connected with the model 3das it may be that the lines are heavier than the solid.
explains this passage better, maybe by attaching a fileobtaining them from structural elements to be inserted in the library and then convert them into sheet metal,
which is in contradiction with what you said before... having all the defined constraints should not be faster?I bring this observation made while developing drawings with the views of a dwg.
As the design is already definitive and I only have to elaborate the production development instead of remaking the 3d by making every sketch start from the 3 views of the imported dwg and work on it.
by curiosity I make a statistics of functions and I realize that with imported sketch, without constraints and without fixed entity the reconstruction is 0.09 seconds; instead putting all the entities as fixed the time sketches to 0,64 seconds.
keep this in mind when you are slowed down
