Dario1982
hello to all, I write to you to undergo a problem that from a little temple we have in the office: you do not know well from which design it started, but in several tables now we literally find a myriad of types of line, as you can see from the enclosed jpeg.. the problem is that even if they are not used in the design, even with the purge do not go away.. The only way I've found so far to eliminate them is as follows: except the file as .dxf, I close it, I reopen it, I do purge (in dxf it works, as well as the "check", which finds so many errors, which in the dwg does not happen) and I climb it as .dwg.. the problem is that it is a rather uncomfortable procedure, and besides, if you make a paste copy also of a simple line from a "infect" design, it "works" also the previously clean one, and returns all that myriad of types line.. How can I do to eliminate them without doing this? Thank you so much!
