exercise drawing of machines
  • Thread starter Thread starter lb020
lb020
I can't tell you what to do. I can't tell you what to do. I should also make the distinction of components, but I have not understood what components are to be distinguished in the holes in advance :wink:
Bye!
first you do not see the annex.
then,as anti-screw systems you could use cut dice, auto-frenating dice or autobloccants.
There are also cups with carving nuts.
Bye!
I try to put it back,es3.webpI have already used it, I have also thought of self-frenating dice and cut dice, but I cannot find any representation, I do not know exactly how to apply them to the drawing. .
Yes, the annex can be seen... I posted it because there is the representation of the cut nut:)
Let us know!
- - - updated - - - -
Let us know!
- - - updated - - - -Yes, the annex can be seen... I posted it because there is the representation of the cut nut:)
Let us know!
I saw, I thought I'd do that in the dead screw, the first left of the second column, could I put the rosettes in a cup? Then in the last two vines, those prisoners, I put self-locking nut in one and self-frenating nut in the other, or do I agree with the dice cut into one of the two?
In my opinion, since it's just a teaching exercise, I don't think it's very important because you have no constraints (such as encumbrance or joint resistance or particular vibrations that could make you prefer one or the other system).
I look forward to the most experienced if I want to say something about it:)
Thank you so much you were very kind!
In the third part of the exercise, I have to correct the views, as errors I have found the lack of sampling in both sections, the lack of the edges of the ribs of both components, and the quotation of the "20 dia" type, besides these are other errors? I also saw that there's a few odds missing, but for the rest, everything seems normal. .
