existing layout as knowing scale factor applied to the window
  • Thread starter Thread starter Agar
Agar
They gave me a dwg, opened it in autocad 2006. inside there is a layout as I know
the scale factor that was applied to the window, is there a way to question the design?
select the layout window and in the property palette check the scale (standard, if you use one of the known, or customized scale reports).
in the property palette there is (safe), missing in the status bar ( fairly secure)
