exploded blocks disappear from the design in autocad 2018
mir
I got a file with a history of conversions etc... I have a dwg with inside solids 3d and blocks ... now if I explode some blocks I disappear of the elements contained (tubes, supports, etc...).
I would like to go to a .sat but the "degenous" blocks prevent me from getting a good job.
advice?
Unfortunately it is too big ... the problem according to me is that it has inside elements made in plant 3d ... others by sat by inventor and a pinch of autocad .... we all know how it works.
try to do this:
enter a block using the command change local reference, using il command _ (or remove) separate any object from the block and then save the block.
In theory you should find outside the block the object removed.
If it works, you could make a lisp go extract all the objects from all the blocks.
If it's too big for a clean one, just a couple of elements that report the problem to be able to do some guesswork.
clean, check that the problem stays and alleges
