exploded design with bubbles and distinct base
  • Thread starter Thread starter davideingSp
davideingSp
Hello everyone
I tell you my problem:
I need to create an explosive view of an axis, so far no problem, I explode everything by placing the components at my liking and then save the view.
I have two main problems:
1) when I go to create a new design this does not show up with the explosive view that I saved earlier but it is all in order we say not exploded.
2) I would like to create on the side of the drawing sheet a table with the name of the part and quantity with relative numbering that is corresponding to the bubbles that indicate the same part on the drawing, unfortunately for this point I do not know exactly how to start, I have sought between the various discussions but always end that they serve parameters, unfortunately I do not know well how to use them since during the course at the university this is a side that has not been treated.
in the table: view states > Explodes visible components and select the name of the explosive view you saved previously.
2) ... unfortunately for this point I do not know exactly how to start, I have sought between the various discussions but always end that they serve parameters, unfortunately I do not know how to use them as during the course at university this is a side that has not been treated.
before moving on to the house, stop a moment, if you have to make the separate with the bubble automatically, you must first define all the necessary parameters, such as code, revision, description, material, weight etc. . as these parameters are inserted in every detail and together, the further you go ahead and more objects you will need to reopen to insert these instructions.
Okay for the first thing, I did it!
for the distinct but now I know that the damage is done, in the sense that the assieme is now ready, the various components are already created.
I would also settle for a separate basis on excel in which the name of the component is reported and in what quantity it is present.
To do this, you say I'd like to create a excel child by hand or is there a way to do it with creo?
At the end of teaching I would still like to learn how to do the work through creo going to set the various parameters, we put that you want to create the design of an explosive and in this design you want to insert to the side a small table with the name of each component quantity in which it is present and relative number to the bubble that indicates it on the drawing.
the right procedure I have to follow is this? :
1 I create the design with the explosive view that I like
2 I collect a bubble with its number to each component
3 imposed in the sheet a table with a number of rows and columns
4 in each cell I write the parameter name I care about after setting it in each part of the axieme
Is that right?
What do you mean?
No. Not in a dream. but where you find this information.
if you add the parameters of the individual pieces, the separate ones come automatically without excel uncomfortable, and the bubbles the same, otherwise there is no possibility. You can't create a table at home and pretend you're getting your bubble.
the fact is that this topic during the course was not treated and so I am trying to arrange as best I can.
Can you tell me how to proceed correctly? In particular I do not understand the passage during which I have to insert the various parameters in the various parts, of each piece I would like to report the name and number of times that appears in the axieme.
I repeat, you have to create the necessary particular parameters for particular. for convenience copy these lines in relationships, so doing you create parameters
weight=mp_mass())
volume = mp_volume(")
material=material_param("condition")
code = ""
revision = "
description = ""
finish = ""
etc. according to the information you need.
the next step is to prepare a table with a column for each parameter and one line where you create a repetition region.
That's all.
