explodes together
  • Thread starter Thread starter sifulee
sifulee
Hello, everyone!
I tried to do an explosion with pro-and wf4, but I gave up because manually moving the components I wanted was too expensive: Since there is a default explosion, but it explodes all the individual parts, can I do so that only the parts/assiems of the 1st level are automatically exploded?
you can do, when you create the exploded state, select the axieme to move into the model tree instead of in the graphic area.
If what you want is similar to the annex (this is simple I have just finished one of 207 components) i.e. a assembly that serves for assembly is not simply to explode the first level.
you sure is a start then depends on the quality of the job you want to get.
if component 1 at first level simplifying is a screw with a nut
and component 2 is a plate.
I can't simply move component 1 to the left or right of component 2, but I will have to move the nut to a part of component 2 and life to the opposite side.
the more complex the axieme is and the better is if the explosive can be traced to more under axioms that are still mountable at the counter completely and that then should only be fixed to a base with screws and thorns or similar.
I thank you for answering me, but I wanted to make it clear that I already had an explosion of a simple assembly (30 components) manually, similar to the pdf dema, also I do the assembling only of welded parts, that is why I stop at the first level, since I do not make complex machines.
I want to apologize with maxopus but I didn't understand how to do it automatically:confused:
You don't understand why you don't do what he told you is:
created a new state of explosion
select the direction and increase
from the model tree selection the first assembly of first level and hand shifts
from model tree selection the second first level assembly and hand shifts
or from the graphic area touch a compote and then select father until the model tree lights up.
exact, the automatic explosion doesn't know if you want to explode the individual components or sub-axis, you do it in manina (for what I know... Maybe someone goes by and does it:-)
sin, I thought you could play some games but I have to resign!
thanks to both and we laugh! !
