explodes together
  • Thread starter Thread starter simolrg
simolrg
Good morning.
to make an explosion together on think 3, first you need to create components?
cordial greetings,
Simone.
I don't know think 3, but the question seems absurd!! If you have a set and there are no components inside what do you explode?
Good morning.
cordial greetings,
Simone.
hi simone, you set the components to make the explosive. .
I suggest you go to the customer care website, or in the online guide, find tutorials and explanations done pretty well on this. .
Matteo
The question is not so absurd, since thinkdesign manages many solids within the same file, and in case of small assemblies you can think of using solids.
I agree, however, that in need of distinct and file size, it is better to create compoenents. .
soon
Matteo
I confirm... you need to work with the components. hello to all and good work!! !
you can do both with and without components.
if you create a component and manage the properties of the file it will be easier to create a separate component.
Overall think 3 is too cool :finger:
