explosion affecting other configurations randomly
  • Thread starter Thread starter mix1977s@C
mix1977s@C
Hello, everyone, I have a little problem with corporate assemblies. .
I have explosives to make an accessory (it is a very close with many positioning configurations and many components.... the fact is that creating a configuration for the explosion, and generating the new view exploded.... the explosion function also affects me other configurations in a "random" way... or not in all but only in some.... obviously sending in v.... the other configurations and annexes placed on the table.... I have already tried to check the "suspend new functions and couplings" both in the exploded and in other configurations... both active... both deactivated.... and active only in the explosive.... is deactivated only in the explosive.... but nothing random applies to me the explosion in other configurations...... has it ever happened?1633431118958.webp
obviously it's under a configuration called explosive... .
but I also influence the configurations above
if you have 5 configurations:
a
b
C
d (to explode)
and
the explosive must be made the configuration d and not on a new adapter created.
Are you in this situation?
This is the situation...
and the exlposion activates me randomly in the subaxis
I removed the rescue and reconstruction before closing.... moved the explosive....checked the options but nothing.. .
a
b
C
d (to explode)
and
I was doing so at first.... then to avoid modifying other people's table sets I opted to create a dedicated configuration.... but I found this problem.... which then is I do the exploding of the d configuration and I find exploded also the b and e configurations.... but random.... not always the same
