explosion object
  • Thread starter Thread starter turitre
turitre
Hi, I'm drawing a lamp in rhino, and it's just that I've been trying with this program.
Attached you will find the view from the top of the lamp that is nothing but a solid made to flaws through boolean operations.
My problem is that I need to be able to handle these flaws individually. I tried through the scan command but the object remains unique and indivisible.
solutions?
solutions?
strange this thing, but is an imported object with another format?
Maybe try to split the object by subdividing the command instead of the Boolean.
solutions?
If you try to right-click the Exploding icon, it gives you the option to extract individual faces. Try this way...
a.c.
So... I remembered that the subdivision in strips I didn't make it with boolean but with the wire cut. I have remade the operation using the boolean and strips you can now select individually. I can't understand why...
