explosives and instant views not up-to-date at the table
MARCOC
hello to all, I stayed behind of several versions regarding the exposed views of inventor
I open the ipn file and I find everything changed as an interface, but this is not a problem, what I don't understand and that once the exploded he automatically creates an instant view that then uses in the table setting
the problem and that a vaulted tavala, if I modify the exploded view on the table does not update (of course I update the snapshot in the hypn)
1638988515875.webpin the table freezes the view and there is no way to make it update
Can someone explain how it works? ?
thanks for the indication peppe, but there is still something wrong...in the sense that I update the table...but I do not see the modification in the ipn...t dx on view...modifies I make the change... and then when save, the ipn does not display the maxla modification table is updated. . .
Does it happen to you? ?
(compared to the explosions I knew about inventor changed everything)
