export 3d file in dwg divided into blocks with individual components.
  • Thread starter Thread starter Per5
Per5
Good morning, everyone.
I am sorry if the speech has already been discussed and rediscussed, but unfortunately I have found so many similar arguments, but nothing seems to do with my case.
I would like if it was possible, starting from a 3d design, whether it be solidworks, inventor, or simply a step, to obtain a 2d of mechanical so that all components are divided into separate autocad blocks from each other.
a similar thing I saw it made by external design offices that used creo or catia combined with me10, excuse me if I am writing strafalcioni, the stalk masses arrived with this subdivision in blocks, in that case each component had a unique block for all the views and already would have this.
I would not want to perform a layer subdivision, because the process seems very long .
We have the possibility to use inventor too, that being autodesk could give some specific command to realize this thing, but apart from the completely sticky dwg transformation I can't find anything else.
Thank you all in advance for patience.
