Thank you so much!! !for the problem that "zippa", you must for once export manually with the command:
file - export - export to dwg, select dwg for autocad, select options and turn off the pack&go optionView attachment 52896
Unfortunately to me also removing the flag from this option remains the problemfor the problem that "zippa", you must for once export manually with the command:
I'm currently working with this code (I don't need the storage number and the dwf so I commented them)
public sub pubblica()
' obtain reference to drawing
dim odoc as document
set odoc = thisapplication.activedocument
' destination folder
dim sexportpath as string
sexportpath = "c:\users\a.botticini\desktop\#esportati_dwg-pdf\"
if odoc.documenttype <> kdrawingdocumentobject then
msgbox ("deve essere aperta una tavola")
exit sub
end if
' get the filename with no path
dim sfilename as string
sfilename = sexportpath & isolanome(odoc.fullfilename, true)
' numero di revisione
dim srev as string
srev = inputbox("revisione tavola? ", "inserisci numero di revisione", "00")
'legge le iproperties personalizzate:
dim opropsets as propertysets
set opropsets = odoc.propertysets
'custom
dim ocustompropset as propertyset
set ocustompropset = opropsets.item("{d5cdd505-2e9c-101b-9397-08002b2cf9ae}")
on error resume next
dim scod as string
' sostituire "codice" con il nome che si usa per l'iproperty che interessa
'scod = ocustompropset.item("codice").value
' if scod = "" then
' scod = inputbox("codice ricambio (inserimento manuale):? ", "inserimento manuale codice ricambio")
' end if
sfilename = sfilename & "_rev" & srev
'& " (" & scod & ")"
' get the dwg translator add-in.
dim dwgaddin as translatoraddin
set dwgaddin = thisapplication.applicationaddins.itembyid("{c24e3ac2-122e-11d5-8e91-0010b541cd80}")
' get the dxf translator add-in.
dim dxfaddin as translatoraddin
set dxfaddin = thisapplication.applicationaddins.itembyid("{c24e3ac4-122e-11d5-8e91-0010b541cd80}")
' get the pdf translator add-in.
dim pdfaddin as translatoraddin
set pdfaddin = thisapplication.applicationaddins.itembyid("{0ac6fd96-2f4d-42ce-8be0-8aea580399e4}")
dim strinifile as string
' common init
' create a context object
dim ocontext as translationcontext
set ocontext = thisapplication.transientobjects.createtranslationcontext
ocontext.type = kfilebrowseiomechanism
' create a namevaluemap object
dim ooptions as namevaluemap
set ooptions = thisapplication.transientobjects.createnamevaluemap
' create a datamedium object
dim odatamedium as datamedium
set odatamedium = thisapplication.transientobjects.createdatamedium
' dwg
' check whether the translator has 'savecopyas' options
if dwgaddin.hassavecopyasoptions(odoc, ocontext, ooptions) then
' file with exportation options
strinifile = "c:\tempdwgout.ini"
' create the name-value that specifies the ini file to use.
ooptions.value("export_acad_inifile") = strinifile
end if
'set the destination file name
odatamedium.filename = sfilename & ".dwg"
'publish document.
call dwgaddin.savecopyas(odoc, ocontext, ooptions, odatamedium)
' fine dwg
' dxf
' if dxfaddin.hassavecopyasoptions(odoc, ocontext, ooptions) then
' ' file with exportation options
' strinifile = "c:\tempdxfout.ini"
' ' create the name-value that specifies the ini file to use.
' ooptions.value("export_acad_inifile") = strinifile
' end if
' 'set the destination file name
' odatamedium.filename = sfilename & ".dxf"
' 'publish document.
' call dxfaddin.savecopyas(odoc, ocontext, ooptions, odatamedium)
' fine dxf
' pdf
if pdfaddin.hassavecopyasoptions(odoc, ocontext, ooptions) then
' options for drawings...
ooptions.value("all_color_as_black") = 1
'ooptions.value("remove_line_weights") = 0
'ooptions.value("vector_resolution") = 400
'ooptions.value("sheet_range") = kprintallsheets
'ooptions.value("custom_begin_sheet") = 2
'ooptions.value("custom_end_sheet") = 4
end if
odatamedium.filename = sfilename & ".pdf"
'publish document.
call pdfaddin.savecopyas(odoc, ocontext, ooptions, odatamedium)
' fine pdf
end sub
'funzione che restituisce il nome del file togliendo il path ed il suffisso
public function isolanome(byval nomefile as string, optional trunc as boolean) as string
'toglie il .ipt
if trunc = true then
nomefile = strings.left(nomefile, len(nomefile) - 4)
end if
dim pos as integer
'ciclo che rimuove il path: trova "\" e tiene tutto a dx
do
pos = instr(nomefile, "\")
nomefile = strings.right(nomefile, len(nomefile) - pos)
loop until pos = 0
isolanome = nomefile
end function
I personally did not know its existence; and anyway I thank you for the report because it seems very interesting to me for the company.But nobody uses this?drawing porter | inventor | autodesk app store
to be able to choose the configuration you must save it first, in the next screen to that post there is the "Save Configuration" button obviously once you set everything as you want. in the drop-down menu, there is also your configuration and if you save with that set configuration you will remain default until you change.@catcher, please know your great availability. :
I would like to know, if it is not to ask too much, how to set a particular configuration for exporting dwg, see image
View attachment 65456I'm currently working with this code (I don't need the storage number and the dwf so I commented them)
public sub pubblica() ' obtain reference to drawing dim odoc as document set odoc = thisapplication.activedocument ' destination folder ' --------------------------------------------------- dim sexportpath as string sexportpath = "c:\users\a.botticini\desktop\#esportati_dwg-pdf\" ' --------------------------------------------------- if odoc.documenttype <> kdrawingdocumentobject then msgbox ("deve essere aperta una tavola") exit sub end if ' get the filename with no path dim sfilename as string sfilename = sexportpath & isolanome(odoc.fullfilename, true) ' numero di revisione dim srev as string srev = inputbox("revisione tavola? ", "inserisci numero di revisione", "00") 'legge le iproperties personalizzate: '------------------------------------------------------------------------------------------------------- dim opropsets as propertysets set opropsets = odoc.propertysets 'custom '------------------------------------------------------------------------------------------------------- dim ocustompropset as propertyset set ocustompropset = opropsets.item("{d5cdd505-2e9c-101b-9397-08002b2cf9ae}") on error resume next dim scod as string ' sostituire "codice" con il nome che si usa per l'iproperty che interessa 'scod = ocustompropset.item("codice").value ' if scod = "" then ' scod = inputbox("codice ricambio (inserimento manuale):? ", "inserimento manuale codice ricambio") ' end if sfilename = sfilename & "_rev" & srev '& " (" & scod & ")" ' get the dwg translator add-in. dim dwgaddin as translatoraddin set dwgaddin = thisapplication.applicationaddins.itembyid("{c24e3ac2-122e-11d5-8e91-0010b541cd80}") ' get the dxf translator add-in. dim dxfaddin as translatoraddin set dxfaddin = thisapplication.applicationaddins.itembyid("{c24e3ac4-122e-11d5-8e91-0010b541cd80}") ' get the pdf translator add-in. dim pdfaddin as translatoraddin set pdfaddin = thisapplication.applicationaddins.itembyid("{0ac6fd96-2f4d-42ce-8be0-8aea580399e4}") dim strinifile as string ' common init ' create a context object dim ocontext as translationcontext set ocontext = thisapplication.transientobjects.createtranslationcontext ocontext.type = kfilebrowseiomechanism ' create a namevaluemap object dim ooptions as namevaluemap set ooptions = thisapplication.transientobjects.createnamevaluemap ' create a datamedium object dim odatamedium as datamedium set odatamedium = thisapplication.transientobjects.createdatamedium ' --------------------------------------------------------------------------- ' dwg ' ------------------------------- ' check whether the translator has 'savecopyas' options if dwgaddin.hassavecopyasoptions(odoc, ocontext, ooptions) then ' file with exportation options strinifile = "c:\tempdwgout.ini" ' create the name-value that specifies the ini file to use. ooptions.value("export_acad_inifile") = strinifile end if 'set the destination file name odatamedium.filename = sfilename & ".dwg" 'publish document. call dwgaddin.savecopyas(odoc, ocontext, ooptions, odatamedium) ' ------------------------------- ' fine dwg ' --------------------------------------------------------------------------- ' --------------------------------------------------------------------------- ' dxf ' ------------------------------- ' check whether the translator has 'savecopyas' options ' if dxfaddin.hassavecopyasoptions(odoc, ocontext, ooptions) then ' ' ' file with exportation options ' strinifile = "c:\tempdxfout.ini" ' ' ' create the name-value that specifies the ini file to use. ' ooptions.value("export_acad_inifile") = strinifile ' end if ' ' 'set the destination file name ' odatamedium.filename = sfilename & ".dxf" ' ' 'publish document. ' call dxfaddin.savecopyas(odoc, ocontext, ooptions, odatamedium) ' ------------------------------- ' fine dxf ' --------------------------------------------------------------------------- ' --------------------------------------------------------------------------- ' pdf ' ------------------------------- ' check whether the translator has 'savecopyas' options if pdfaddin.hassavecopyasoptions(odoc, ocontext, ooptions) then ' options for drawings... ooptions.value("all_color_as_black") = 1 'ooptions.value("remove_line_weights") = 0 'ooptions.value("vector_resolution") = 400 'ooptions.value("sheet_range") = kprintallsheets 'ooptions.value("custom_begin_sheet") = 2 'ooptions.value("custom_end_sheet") = 4 end if 'set the destination file name odatamedium.filename = sfilename & ".pdf" 'publish document. call pdfaddin.savecopyas(odoc, ocontext, ooptions, odatamedium) ' ------------------------------- ' fine pdf ' --------------------------------------------------------------------------- end sub 'funzione che restituisce il nome del file togliendo il path ed il suffisso public function isolanome(byval nomefile as string, optional trunc as boolean) as string 'toglie il .ipt if trunc = true then nomefile = strings.left(nomefile, len(nomefile) - 4) end if dim pos as integer 'ciclo che rimuove il path: trova "\" e tiene tutto a dx do pos = instr(nomefile, "\") nomefile = strings.right(nomefile, len(nomefile) - pos) loop until pos = 0 isolanome = nomefile end function
