export by name without spline
  • Thread starter Thread starter Tarkus
Tarkus
Hello, everyone.
in sheet metal environment, when you make a hole not perpendicular to a face or similar processing, the flat model (of course) reports that hole as an ellipse or another complex figure that once created in dxf with "export face with name turns out to be a spinline.
If that dxf I have to cut it, not all laser cutting software read the splines. (for example my) :rolleyes:
Does anyone know if there is an escamotage or an application that transforms the spline into many arches, without having to handle it? :biggrin:
p.s.
:36_1_18: those that will suggest me to change software to tlaser will be released immediately.:36_1_15:
Hello, everyone.
p.s.
hello tarksus according to me you should do manually! ps answer in my forum pls
if it is not explicitly provided use the dxf r14 or r2000 format that does not support the spline automatically converts them into multiline
Good.
converts them into polylinea, but at this point it is enough to explode them. .
a single mole: it "translates" me a radius arc of about 300 mm in a myriad of lines of length about 0.1 mm.
How can I give him a bigger resolution?
(maybe it's a bit ot,it's more a question from autocad forum... )
