export custom bookcases inv 2010
  • Thread starter Thread starter spy280
spy280
Hello, everyone. I have the following problem:
I must export a custom library (inv2010) from fixed to portable pc(always inv2010)
I leave the process for the creation of a new library, but I would like to explain step-by-step the procedure I made to import it into the laptop, to understand where my error is.
-apro adms 2009 and load the .mdb file of the copied library
-apro inventor and set with “configure libr. centro contents” the library that I want to load
-enact the library and save the active project
at this point, if I open a new .iam file, and I go to search from the content center the newly uploaded library, here I do not show it, but if I go to, editor center content (to see if there is the library and point everything on the filters) , this makes me see it, but inside it there is nothing.
Where am I wrong?
thanks to those who can answer
I'm sorry, but I'm not following you. .
if from the center editor contained, in the drop-down menu I can see the newly uploaded library, in theory the active project, loaded the exported library.. or did you mean another thing?
I didn't understand something sincerely. . .
how amount did the parts that I published in the cc from 2009 to 2010?
they told me that adms console in 2010 no longer exists
and I did not understand why the type of assistance that installed me the new version has set me the pointing of the center contained on 2008 that has uninstalled (but the cc works...) what I will learn soon. . .
So I'm in the poop now if I don't get the things I've created. And I have no intention of republishing the stuff..
for your problem, I try to solve it myself, you have to open the project mask over the key made there is an icon that is called set up library center content. Try to see if it's connected to your project you're using. in case it wasn't connected
the fact is, that in the active project, the library is connected to the project, using precisely "configure library center contents"....but also I do not find the parts inside the library.. .
what dexter said is what I meant:
but I responded quickly and without trying and actually if you see it on one side you have to see it on the other.
But now, since he left it in the first post, you also explain how you exported the library you want to import and that families are inside it?
Then, I open amsd 2009, I go under the library folder, and I right click on the library that I want to export and do "export".
Then a new window opens, where I can decide where to save the library.
once saved, inside I find the 2 .mdf and .ldf files
the families inside, they are copies of vices, but I need to change the material and give it the company code.(all this not to hack the default libraries)
