export dwg multifoil boards
  • Thread starter Thread starter Pablo
Pablo
when exporting in dwg or dxf a board with 2 or more sheets, then opening the dwg file I always find the last sheet exported to paper space and not on model. Does anyone know any solutions? Settings during export are "export all sheets to a file" and disable "export all sheets on paper space". I do not use custom mapping files
That's why he wouldn't know where to put the most sheets in the model space. the first puts it in the model space, all others in the paper space.
should "analyze" the sheets and spread them into the model space, detaching them appropriately so that they do not overlap. very difficult to implement.
I solve by copying the tables and pasting from paper spaces to model space and then erasing all layouts.
I haven't found any other solution today. to split the sheets into single .dwg I find it even more slender if you want a unique .dwg.
it would be nice if it had, as you say, the sheets in one model space. . .
I thought there was some options to set, so I was wrong!! thanks for the info
