export dwg to an extension by cam path
  • Thread starter Thread starter iron72
iron72
Hello.
I wanted to know what the file format is to create a cam path.
specific that I use a two-axis and a half cutter so I do an interpolation only on x,y axes. I just need the positioning.
I believe that on the type of export file for things like that can answer you more who deals with mechanics!
I move the discussion.
depends on formats supported by the cam software that will be used. . .
However, in general from cam software is much more frequently supported the dxf format than the dwg format, among the autocad ones. in any case, you have to ask who will develop the path (evidently not you); He's the only one who can really help you.
