export dwg
  • Thread starter Thread starter power23
power23
Hello, guys.
do you know if it is possible to export the table of a sw axle in dwg...maintaining the individual details as blocks?
What I know most has this possibility... have you ever had to do it?
Thank you!
Hello, guys.
Thank you!
as blocks I don't know, but if before export you put them each in a layer
you can always group them after saving in .dwg.
I'm not 100% sure, but I've never seen an option like that, I assume you can't. I also thought about the same mike solution, but it is still quite "manual" the allocation of layers to the various components.
I also happened to have this need and the only solution is to manually assign a different layer for each part but it is not at all convenient because it is a long-term operation. I have to look for if there is any macro that helps in this thing.
