Hello, I have a problem, exporting to dxf the table from solidworks 2021 I enlarge the outline lines excessively, I tried in the options of the document to change settings but nothing... I attach the file
select everything and change the line thickness from the command in the bar.. .or if you have autocad change the thickness from them, in the layer settings.
in autocad you do not need to change the thickness of the layers, but just turn off the display of the thickness.
also for export from solidworks you can properly set the mapping file
ok was set the line thickness 0.5 mm in document ownership. I put 0.25 right now. bison also change it in the default file otherwise you have to change it every time manually. . .
