export images from autocad
  • Thread starter Thread starter gil
gil
In order to publish some of my projects, I need to export the drawings currently in “.dwg”, in image format for the web and something to insert in a printable portfolio.
by autocad I could use a virtual print, the method works, but the images I get, although acceptable, are not exactly the maximum, especially with curved lines. do you have any suggestions to make?
now the best results I get them using virtual prints in “.png” and “.eps” format (post script level 2).
I also tried to open the dxf file with graphics programs, but with significantly worse results.
I tried the export in pdf. Unfortunately, the final result does not bring any improvement.
apart from it, but you asked in pictures (so I think jpg,tif).
I set it up like this.Senza titolo-1.webpand this is the autocad print on the fly
