export modes of vibrating in text format
  • Thread starter Thread starter francesco_design
francesco_design
hello to all;
I performed in ansys 12 a modal analysis of a component and would be interested in exporting in text format the list of shifts of knots for every way to vibrate. for example, in relation to the first two ways, the commands I use are as follows:
/posts
set,list,1
set,,,
/output,modo1,txt
/output
set,list,1
set,,,
/output,modo2,txt
/output
the problem is that text files (in the example mode1.txt and mode2.txt) are created but remain empty without any text line; I thank anyone who wants to give me an indication of how to solve this.
Strange, they should go.
if you remove all /output directives the prnsol command works well (i.e. you see the results correctly)? ? ?
Yes; the prnsol command works correctly. I managed to solve the problem by grouping the same commands into a text file and reading the latter to ansys through the "read input from" function in the "file" menu. in this way the commands are executed correctly and the text files do not remain empty.
