export problems from revit to dwg
  • Thread starter Thread starter andrea.fac
andrea.fac
hi to all I have a problem with exporting a file from revit to dwg format, in practice when I carry the views in the plant on some of them remain drawn old solutions exceeded.
opening the file in autocad I find myself to examples some doors scattered for the drawing, doors with the sense of inverted opening or unupdated retinatures.
Please help me.
Hello and thank you
thanks for the answer, the version is 2008.
the export procedure is correct and has always worked.
objects that are not properly distracted are, for example, deleted doors and windows or with the inverted opening direction.
Hello and thank you
the commands of ver. 2008 I do not remember them, however: try to clean the revit file (file>elimina unused> ..) before exporting to dwg.
if I don't remember badly, some families of default doors and windows, in the ver. 2008, had the problem "inversion" during export in dwg.
try to use another type of family of doors and windows and check if export to dwg creates the same problem.
thanks for the answer, but the proof of "cleaning" the file I have already done eliminating all families etc. unused.
the family that gives me problems is not one of those of defoult and also on 50 inserted families are only a couple that are exported wrongly.
then take into account that I find myself some doors in places where never existed walls!!
p.s. I have another problem, during the export I also noticed some machines inserted as detail are placed incorrectly.
.... also on 50 inserted families are only a couple that are exported wrongly.
therefore the problem is related to the family(s) used. you should use other families, or build new ones....
no the problem is not the faults it would be so if it did with most instances inserted or with those clumsy compared to the pase.
in other projects the families used never made me problems
