export problems in eps with autocad 2013 for mac
  • Thread starter Thread starter saro
saro
hello to all
I have a problem with export to eps from autocad 2013 for mac.
I have seen that there are other posts with my own problem but I see that there has not been a resolution at the end. eps that do not correspond to the size of the table I set, as well as always appear vertically. Where am I wrong?
Hello, if you kindly tell me the purpose of exporting to eps, maybe I can indicate a better solution, since for my albeit tiny experience, I realized that autocad and eps often do to horns
He's perfectly right,
export to eps I need for prints to do on a professional server. where they can't print from dwg and I found that the quality of pdf is not even excellent if not set by the distiller correctly (which I can't do for now)
the problem that I should save tables in a1 in horizontal eps, but from autocad for mac I get out of eps in a4 vertically cutting all designs.
then while with autocad for win make the epis is quite simple above all set the quality of the epis (300x300, 600x600, 2400x2400....) with autocad x mac I can not do the same things or at least I do not know where they set up.
Thank you for your help.
The solution, free, is called inkscape.
import dxf, export thousand formats, including eps.
pass word, we promote free software.
ok apart from free advertising
I do not know if it will be the solution but going on this link: http://inkscape.org/en/download/mac-os/ What am I supposed to download? xquartz software?
and then I still have the snow leopard operating system (10.6.8) also works for this?
a solution inside autocad is not there? :mad:
