export problems with rhino
  • Thread starter Thread starter PietrodeAngelis
PietrodeAngelis
Sorry, guys, I have a problem with rhino. I hope you can give me some advice.
the program crashes (not responding) when I try to export the file to step (or iges )
It is a simple open polysurface as I have made thousands. . .
what could be treated.
the 3dm file is 23m... even exaggeratedly big
thanks in advance! !
pietro
Perhaps it could be insufficient ram, the file is not just small to be divided into surfaces.
Try to explode it first, and maybe split the export several times, do some evidence.
pietro
It could be a corrupt superfice that fails export.
Explode the surface and then go to the diagnostics menu > select bad object
or copy and paste this command: _selbadobjects
if there are corrupt surfaces.. select them
first of all thank you.... found 3 invalid surfaces... but still manages to combine all surfaces.
Is there a way to fix them automatically?
