export retini from autocad map to shp
  • Thread starter Thread starter jeanpier01
jeanpier01
Hello everyone
I have boards with retinals designed with autocad (autocadmap with precision) and I need to export the nets in shp format to read them with gis software.
Can you tell me how to do it?
very simply.. Don't do it. shapefile does not contain information about thematicization
But I could export a polylinea like shp and once imported into gis I could give it a filling; Right?
How can I export a polyline that is recognized by the gis as a closed entity?
the polylinea is closed and also exporting with the mapexport command in gis I can not see it as a pole
evidently you did not appear, in the "options" tab of the box "export", the flag "treated the polylinees closed as polygons"
I take advantage to ask you another info
I have a dwg with multiple layers; can you export it to a shp while keeping the layer subdivision?
In other words, I wish that when I open the shp I find myself somehow:
Level 1
Layer
etc.
Is it possible or does it export them all on one level?
the shapefile does not have a "stratified" structure. you should rather create a shapefile for each layer
