export revit to jpeg
  • Thread starter Thread starter Delphine
Delphine
hello to all and good year!
I have a little problem that only appears lately. when I would like to export prospects/sections from revit to jpeg, the image in jpeg comes with thick lines, despite in revit both with thin lines. Where am I wrong?
the problem continues, even with very high number of pixles.
can be understood because the project is small and I have to zoom a lot to see the plants/sections/spects... ?
What in curtains to "supple a lot"?
the scale of the view can be set to suit: from 1:1 to 1:5.000. set the value you need of the scale (properties seen > scale view) and then export.
you can also use the "visible part of the current window" option to export the view to multiple parts and then reassemble it with an external image editor (photoshop)
I regret this debate for such a problem.
I when I take a section (hidden or shady line) then on photoshop I see it in wireframe. In practice I also see the things that should be hidden from the wall in front of me.
What to do?
Hello and thank you
You mean exporting a section view (no wireframe) as image file, do you see it as wireframe?
... to me, it doesn't happen
