export the layout into the model projecting solid 3d on a projection plan
  • Thread starter Thread starter Naeto
Naeto
Hello
I have the following problem:
when I try to export in the model a layout of a 3d design with the command "_exportlayout" everything works regularly but if then I try to rotate the saved design I see it is still three-dimensional
....is it possible to get a 2d model?
Sorry if this topic has already been dealt with, but at the moment I have not found references
Hello
What do you mean, "three-dimensional"? are 3d lines or is it still a solid?
from what I see are blocks with surfaces......I want to flatten everything because it is a scale, I have to extrapolate the bundles and various plate for laser cutting
