export to dwg a *.iam not removable
  • Thread starter Thread starter Brethil
Brethil
Does anyone know by chance how to export a *.iam axieme file in *.dwg format, making sure that the resulting 3d *.dwg file in autocad does not uncommon and remain solid?
I don't know if you have to make the solid axieme before in inventor or if you can freeze the layer in autocad after; Maybe with a nice password, so that the customer does not remove the treddi...
Any suggestions?
thanks to all in advance
I solved it myself, for who was interested:
create a simplified part from your iam file; once you get its ipt file as unique solid, go in autocad and do new acadiso.dwt, then import the ipt file in autocad and you will have your complete 3d model, which if it is exploded; as a result of only a billion useless lines and not the individual parts of your original inventor set.
Perhaps there are better and simpler methods, this is my self-taught.
