export to failed dwg (blank view)
  • Thread starter Thread starter il disegnatore
il disegnatore
Good morning to all
I haven't been able to export a drw in dwg since yesterday, finally seeing the real views. (version sw 2015 sp 5.0)
no setting was changed and I performed the same operation from more than one location.
allego print error.
Have you ever faced such a problem?
unfortunately there is no problem only with puts in the table with many components (the complete machine can have 5-10.000 components if not more)
now the problem arises on axes from 100 pcs.
Can anyone help me with that?
how we can help you understand the problem if you can't export. What do you have to export? If you don't have any privacy issues attaching some mods, otherwise we can't do anything. sometimes from export error messages, but to me every time you have given them they were not a great deal of serious. tried to export even in a different format beyond the dwg? type pdf, dxf...
Hi, drake.
Unfortunately I have to export only to dwg if even for some reason can do so in pdf I am not of help.
I would not have created confusion by calling "export" a simple drw rescue in dwg.
I don't know what I can attach. . I would have to make a pack&go of all a 100mb machine project and beyond.
The only thing I've found on the net is the possibility that a few pieces can bother... so you have to find it and suspend it, after which it should work. (in the perspective of a complete machine with 10000 pieces and beyond is a very fast thing to tell me... )
other ideas/possible solutions?
try to simplify the table. in the sense that if you have a table with multiple views, delete views and export and see if it succeeds in this case. Otherwise it is practically impossible to solve it. . .
if there are components that usually annoy those imported or with surfaces. this to begin to screech.
The problem alone with it?
try to do: put everything in quality draft, hide hidden lines, export to dxf...
What kind of views are the offenders?
is already simplified at most, it is a machine layout, so there are the classic 4 views.
I know that many times it is the section to create problems, in my case it is not really present.
but doing a test and going to insert it I see that it generates it without problems (when I open the dwg but I only see the dotted sampling without contour lines)
exporting to dxf unfortunately does not change the result
[MENTION=16601]mammals[/MENTION]....it happens only with assemblies, but it could also be a coincidence (because maybe if I can identify the incriminating component the error also comes with the table of the single piece)
The incriminated views are...all. opening the dwg you see a drawing with only the cartilage.
also putting in quality draft etc. the result does not change
the problem is that there are 15k components, I do not find there is a function "relevating components that annoy them". Did I really have to go on trial?
I guess you need assistance. I told you to try to see a single view, x understand whether alone the problem, or arises when it has to process more data due to the contemporary presence of more views. to me every time you give me these problems, I always screwed them, because it wasn't important export in dwg. did you try to set a different export of the spline in the options? could also depend on these options.
starts suspending all the vines, seeger, thorns and chincaglieria like that.
launches the dwg
then suspend imported parts and with surfaces
launches the dwg
the only way is to proceed for exclusion with great patience
launches the dwg
launches the dwg
ok thanks, I will try to suspend half the files, then further reduce the scissor. .
having recently had the same problem, I can also advise you to:
open a subaxieme at a time and execute instruments > currency > check > check
then try to understand what the part that generates the problem (it is indicated with a yellow arrow)
Gabriele
