slurpix
I press that I have never used thinkdesign, but now I have a tot of drawings in e2 and e3 format and should export them to dfx/dwg
x export them to the format I want to go simply on "Save as" --> dxf or dwg --> ok
and he exports me the file
only that then, opening it with autocad or with other I see that the quotas did not export them correctly, but they are double, or moved regarding the original, or detached from the quota line
I tried to change some options on rescue properties, but nn I solved
Is there any option I didn't activate?
ah usage thinkdesign 2011
Thanks
Thanks
